Converts special characters in a string (such as <, >, &, ', ") into their encoded entity forms. Use it when you need to safely store or transmit text that may include reserved characters.
Encode HTML-sensitive characters
{{htmlEncode record.content}}Input:
{ "record": { "content": "<div class='alert'>& Goodbye \"world\"</div>" } }Output:
<div class='alert'>& Goodbye "world"</div>
Use this helper when sending data that should not be interpreted as markup, such as embedding text inside HTML templates or storing raw text in databases.
Only special characters are converted; plain text remains unchanged.
Combine with
htmlDecodeif you need to safely switch between encoded and decoded forms.
