Converts a number into its ordinal string form (e.g., 1 → 1st, 2 → 2nd, 3 → 3rd). It correctly handles special cases such as 11, 12, and 13, which use the th suffix.
Ordinalize basic numbers
{{ordinalize record.a}} {{ordinalize record.b}} {{ordinalize record.c}} {{ordinalize record.d}} {{ordinalize record.e}}Input:
{ "record": { "a": 1, "b": 2, "c": 3, "d": 11, "e": 22 } }Output:
1st 2nd 3rd 11th 22nd
Ordinalize values from record fields
{{ordinalize record.rank}}Input:
{ "record": { "rank": 4 } }Output:
4th
Works with both numbers and numeric strings (e.g.,
"5"→5th). -
Will not work with negatives, floats, or text strings.
The helper ensures correct suffixes (
st,nd,rd,th) even for tricky numbers like 11, 12, and 13. -
Useful for displaying ranks, steps, or ordered positions in a user-friendly format.
