Removes the protocol (http://, https://, etc.) from a URL, returning a protocol-relative path.
Remove protocol from a CDN URL
{{stripProtocol record.cdn}}Input:
{ "record": { "cdn": "http://foo.bar/image.png" } }Output:
//foo.bar/image.png
Useful for ensuring links work correctly across environments where protocol may vary.
The helper preserves the rest of the URL, including domain, path, and query parameters.
Combine with
stripQuerystringif you also want to remove query parameters while keeping the domain and path. -
Values that are already protocol-relative (
//example.com/...) remain unchanged (no duplicate forwardslashes). -
Only the first occurrence of
<scheme>://is removed. For example,https://example.com/redirect?url=http://other.com, only the leading https is removed; thehttp://inside the query remains. -
Scheme matching is case-insensitive and can handle HTTP(S). FTP, WS, and
h2://.
