trimRight helper
Removes only trailing whitespace from a string, leaving leading whitespace unchanged. Use it when values may include extra spaces at the end that need to be cleaned up.
Usage
{{trimRight value}}
  • value (required): input string
Examples
  1. Remove spaces from the end of a string
    {{trimRight record.text}}
    Input:
    { "record": { "text": " ABC " } }
    Output:
    " ABC"
  • Only trailing whitespace is removed; leading whitespace remains intact.
  • Use this helper when exporting values where leading spaces are meaningful but trailing spaces should be discarded.
  • Pair withtrimLeftif you need to remove both leading and trailing whitespace.
