Removes everything after the ? in a URL, returning only the base path. Use it when you need a clean URL without query parameters.
Remove query parameters from a URL
{{stripQuerystring record.fullUrl}}Input:
{ "record": { "fullUrl": "https://example.com/product?ref=ads&utm_source=google" } }Output:
Remove query and fragment
{ "record": { "fullUrl": "https://site.com/page?x=1#section" } }Output:
The helper only removes the querystring; the main path of the URL remains unchanged.
If a ? is present, everything from ? to end is removed (fragments after the query are dropped). If there’s no ? before the fragment, the URL is unchanged.
Works on plain strings and file paths (e.g., "
/local/path/file.html?version=1.0" → "/local/path/file.html"). No URL validation or decoding is performed; the helper is simple string truncation at the first ?.
