Converts a string into pathcase by replacing spaces, dashes, underscores, and other non-word characters with forward slashes (/). Use it when you need to format identifiers or labels as path-like values.
Convert a mixed string into pathcase
{{pathcase record.input}}Input:
{ "record": { "input": "a-b-c d_e" } }Output:
a/b/c/d/e
Split camel/pathcase
{{pathcase record.name}}Input
{ "record": { "name": "getUserProfile" } }Output
get/user/profile
All separators (spaces, dashes, underscores, symbols) are normalized to
Lowercasses all segments with digits preserved (e.g.
v2,v1) -
Useful for generating folder-like paths, URL fragments, or grouping keys.
Consecutive non-word characters are collapsed into a single slash.
Non-string datatype inputs (like numbers or boolean) are converted to strings before processing. Arrays of primitive types (like strings or numbers) are converted into a comma-separated string before processing. If inputs are objects or object arrays, the output will be unusable.
