reverse helper
The reverse helper reverses the order of characters in a string. Builders use it in Handlebars templates — including field mappings, response mappings, HTTP request bodies, and dynamic API paths — for tasks such as creating obfuscated identifiers or transforming values during testing.
Usage
{{reverse value}}
value -- The string to reverse. Numbers are converted to strings before reversing. Required.
Examples
Reverse a word
{{reverse record.word}}
Context
  "record": {
    "word": "abcde"
Output
edcba
Reverse a name
{{reverse record.firstName}}
Context
  "record": {
    "firstName": "Jane"
Output
enaJ
Notes and constraints
  • The helper works on any string input. Numbers are converted to strings before reversing.
  • Whitespace and punctuation are preserved, in reversed order.
