Removes only leading whitespace from a string, leaving trailing whitespace unchanged. Use it when you need to clean up values that may have extra spaces at the beginning.
Remove spaces from the start of a string
{{trimLeft record.text}}Input:
{ "record": { "text": " ABC " } }Output:
"ABC "
Only leading whitespace is removed; trailing whitespace remains intact.
Use this helper when importing or exporting values where trailing spaces are meaningful but leading spaces should be discarded.
Pair with
trimRightif you need to remove trailing whitespace as well.
