If you’ve configured an Amazon MWS connection using the Amazon - Canada or Amazon - Japan IClient, you must create a new authorization token and re-authorize the connection. You can re-authorize the token using the Developer Account Number mentioned in the Developer access for Celigo in the Amazon Account article.
To configure an Amazon connection for the Canada and Japan marketplaces, do not use the Amazon - Canada or Amazon - Japan IClients.
When you’re generating the authorization token, you can use the:
Amazon - North America IClient for Amazon - Canada, and
Amazon - Australia IClient for Amazon - Japan
Log in to your Amazon Seller Central account.
From the top bar, navigate to the appropriate marketplace (if you have multiple marketplaces configured from one Amazon seller account).
From the left menu, go to Partner Network > Manage Your Apps.
On Manage Your Apps page, click Authorize new developer .
On the Authorize new developer page, enter the Developer’s Name and Developer ID in their respective fields by referring to the Developer access for Celigo in the Amazon Account article.
Click Next.
On the Authorize new developer page, read through the terms mentioned and check the box highlighted in the below image.
Click Next.
The account identifiers such as Seller id , Marketplace ID , and MWS auth token are generated and displayed.
Log in to your integrator.io account.
Click on the Amazon - NetSuite integration app tile.
From the top-right, select the appropriate Amazon account from the drop-down menu that is used for CA or JP marketplaces.
Go to Connections , and next to the appropriate Amazon connection that is been used for CA or JP marketplace, click Actions > Edit connection .
On the Edit connection window, update the connection with the Seller id , Marketplace ID , and MWS auth token details generated above while authorizing a new developer.
For CA connection, in the IClient drop-down menu, select Amazon - North America
For JP connection, in the IClient drop-down menu, select Amazon - Australia
Note: From the IClient drop-down menu, do not select Amazon - Australia (Beta) option.
Click Test connection .
On a successful connection, click Save & close .
