You can set up an HTTP connection to an open-source application that requires no authentication. Before creating the connection, review your app’s API guide. It will provide the necessary information, such as its URI and endpoints. Every app puts its documentation – guides and reference material – in different places. You can often find it by searching for “API guide” or “API documentation” on the company’s website.
From the Resources menu, select Connections. Then, click + Create connection at the top right.
–OR–
While working in a new or existing integration, you can add an application to a flow by clicking Add source or Add destination/lookup.
At this point, you’re presented with a series of options for providing HTTP endpoint authentication.
Mode (required): Select one of the following options
Cloud to connect to a publicly accessible server application.
On-premise to connect to a server that is publicly inaccessible and has an integrator.io agent installed on it.
In the Create connection panel, select Custom for the Auth type. Then, save & close.
Save – click this button to test the connection, commit the new connection so that it will be available to all integrations for your account
Save & close – click to test and save the connection and exit the Create connection pane
Close – click to exit without saving any new changes
Test connection – click this button to verify that your new connection is free of errors
When you test or save the connection, it is verified before continuing. If the connection fails, double-check the provided settings and test again.
