truncateWords helper
The truncateWords helper shortens a string to a specified number of words and optionally appends a suffix. Use it to limit text length in summaries, previews, or any field with a word count constraint.
Syntax
{{truncateWords string limit suffix}}
string -- The string to truncate. Required.
limit -- The number of words to keep. Required. Must be a non-negative integer. 0 returns only the suffix. Negative or non-numeric values return an empty string.
suffix -- The string to append after truncation. Optional. Defaults to …. Pass "" to truncate with no suffix.
Examples
Truncate to different word counts
{{truncateWords record.description 1}}
{{truncateWords record.description 2}}
{{truncateWords record.description 3}}
Input:
{ "record": { "description": "foo bar baz" } }
Output:
foo…
foo bar…
foo bar baz
When the word count is equal to or less than the total words in the string, the string is returned unchanged with no suffix.
Use a custom suffix
{{truncateWords record.notes 2 "--more"}}
Input:
{ "record": { "notes": "Integration setup requires testing" } }
Output: Integration setup--more
Truncate to zero words
{{truncateWords record.description 0}}
Input:
Output: …
A limit of 0 returns only the suffix.
Usage notes
  • Truncation respects word boundaries -- no partial words are returned.
  • If the word count is less than or equal to limit, the string is returned unchanged with no suffix appended.
  • A limit of 0 returns only the suffix. A negative or non-numeric limit returns an empty string.
