Configure SSO with OneLogin
Use the following steps to configure SSO with OneLogin:
Add the integrator.io app to your OneLogin account
  1. Create a custom OIDC connector using the steps in the OneLogin help article: OpenID Connect (OIDC) Custom Connector. When you can access the Client ID and Client secret, stop. You'll finish configuration in a later step.
  2. In OneLogin, copy the Client ID, Client secret, and Issuer URL. Do not close OneLogin, you'll return here in a later step to complete your configuration.
  3. In integrator.io, go to Account (your avatar at the top of the page), and select Security.
  4. Navigate to the Single sign-on (SSO) section and enter the Issuer URL (including https://), Client ID, the Client secret, and your Organization ID from OneLogin that you copied in step 2.
  5. Select Save to see the Application login URL and Redirect URL. Copy these, you'll need them to finish configuring OneLogin.
  6. Return to OneLogin to complete setup. Enter the Application login URL (Login URL) and Redirect URL from integrator.io into OneLogin.
  7. Save your changes in both OneLogin and integrator.io.
