Scayle is a cutting-edge e-commerce infrastructure platform that provides scalable solutions for building and managing online stores, offering robust features for inventory management, order processing, and customer engagement.
Instruction |
API type * |
Choose your Scayle API type:
Subdomain * |
Enter your Scayle account subdomain:
API version (This field is visible only when you select Storefront as the API type) |
Select your Scayle account API version. |
API key * |
Enter your Scayle API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic, cookie, custom, digest, JWT bearer, OAuth 1.0, OAuth 2.0, token, and WSSE auth universal connector documentation.
Sign in to your Scayle account.
Navigate to Settings > General > API keys.
Click + Token.
Click Create token.
Copy the API key.
